Greg
I don’t think that would show you anything because there isn’t a load on the transfer case in the form of a long, angled driveshaft with a double cardan joint on it.Would this test work?
Disconnect both driveshafts at the transfer case. Then put the transfer case in 4 wheel drive high. Then put it in drive and go through the gears until you hit highway speeds. I'm not sure how an automatic would work in this scenario or if it would even shift... In a manual, you could simply put it in 5th and rev up to 3,000 RPM. That would spin the both yokes on the transfer case at highway speeds while the Jeep is stationary. If the vibration is still there, then the transfer case is the problem. If it isn't, then the driveshaft must be the problem.
The double cardan is going to transfer any play in the transfer case down through the driveline. I’m having trouble finding the words to explain this, but that output shaft has to be solid or else the double cardan is going to be flopping all over the place.
