After reading about the gears used in 4 low I should have mentioned that while 90% of my off roading in the CJ was in 4 low, about 50% of that was started out in 2nd.
No 2lo ?Most of my wheeling in the past has been in either 2hi or 4hi.
When I'm in 4Lo, I'm in 1st 99% of the time but if it's easy enough to have to use 2nd for more than 10-20' I shift to 2wd. I don't have any trails I can't do in 2wd that I'd bother using 4Hi for. I would use 4Hi briefly to get through a long deep patch of sand or mud but that's it.
No 2lo ?![]()
I drive in 2wd until I get stuck then I check the situation, and see what I need to do, but most likely I put it in 4 low then hit the rear locker, then the front locker, and if all else fails. PLAN B (the winch)
I’m in 4 hi ASAP when I hit dirt roads and slick situations. Locking them up after you get stuck isn’t wheeling is it ? You got to lock them up beforehand
My thought is if you are locked up, and get stuck, you start running out of options. I like to have more options. I should have added that if I get good and stuck, I also have a hilift Jack that I can use to lift my tires off of the ground and push it over. Really my only fear is broken parts.
Not really stuck if I just lock up, and get out right?Do you know why you got stuck ? Cause you weren’t locket up
4 hi 75%
4 lo 25%
Locked 15% of the 4wd time
I have a sport, and I've been told I have a dry sense of humor, never been told I was funny per se:nusenuse:
Embrace that fear.My fear would be popping myself in the jaw with that Hi lift
Embrace that fear.
Yeah the Hi lift can be intimidating. I have actually wheeled with one pretty much my whole wheeling life, and never had an issue, but if you don't respect it, that can definitely happen.
If you are out there alone, it is another option, and I say bring all of the options you can. It is pretty easy to carry one, so why not? Even if you are not alone, it is another option if everybody is stuck or broken. I never go wheelin' without it.
