Jeep Wrangler Rubicon Wiring Harness Question
Jay MacLeay
Los Angeles, CA, United States
My Jeep has been intermittently sputtering and stalling. I took it to the dealership near me, they told me the problem was with the engine wiring harness. They said that the wiring harness is stretching, which caused one of the wires in the wiring harness to become disconnected and then reconnected... most likely a pin in one of the plugs. They said the best way to fix this problem is to replace the wiring harness, but Jeep doesn't make replacement wiring harnesses for TJs.
So, I'm looking for used wiring harnesses. I'm wondering if I need to find a wiring harness from a Rubicon, or if I just need to find a harness for a 2005 - 2006 4.0 6speed. Any advice would be greatly appreciated.
Also, I should say that this forum has provided me with more support than the Jeep dealership I took my Jeep to has.
You know who might know the answer for sure, @RangerRick. Let's see if he chimes in, as I too am curious of the answer.
Wire harness is stretching?
That seems pretty vague? What wire in particular is disconnecting and reconnecting? If it were me, I would just fix that issue.
Check the fuel injector wiring harness where it passes around the threaded stud next to the backside of the valve cover. The insulation can be worn away there and cause problems with the fuel injectors.
Yea, stretching is what they told me. I'm not sure which exact wire is causing the problem, and the dealership couldn't tell me. I think, because the problem is intermittent and not constant it's hard to tell exactly which wire it is. After connecting and reconnecting the plugs from the ECU, I had to zip tip the connectors to the ECU because the plastic clip that is supposed to lock them in no longer does. Thanks for the fuel injector wiring suggestion, Jerry.
Man that is really a crap diagnosis. I hope they didn't charge you for that. Seriously they plugged an ALDL in and looked for codes then didn't find any blamed the wiring harness and pushed it out. Really leaving you hanging and on your own. That in my opinion is really shitty work.
I may get it, if they told you that they will charge you real time for diagnosis and give you the option, but the way they left it seems like if you buy a new wiring harness, of which they didn't even tell you what you needed, and it doesn't fix the problem, that they are not on the hook. That is really BS.
I know me complaining about your dealership doesn't help your issue, but I don't think you need a whole new harness based on their diagnosis. Plus, I would be curious to how many patrons on this forum with lifted Jeeps have had problems with wire harnesses stretching. I am betting it is pretty rare.
Rather than spending money on a wire harness, (Unless you are going to get one for the dealer and they are going to put it in, and be on the hook for their diagnoses) I would spend a few hours at a reputable jeep shop for a better diagnoses. with the caveat that if it is a wiring issue, they fix it, or tell you what the issue is or you are not paying. Most shops wont actually deal like that, but what they will do is charge you two hours labor, and tell you where they are and then ask for more time, but if they haven't gotten anywhere they usually don't charge you.
Not being able to hear your Jeep or drive it I really can't help you much. I think @Jerry Bransford is good advice, but if that isn't an issue, you are back at square one.
I don't know how much of a mechanic you are, but my advice would be to check for codes, but i am assuming you don't have any or the dealer would have been all over that.
Basically, if you don't have codes, I doubt you have a wiring harness issue, not to say it is impossible, but I think it is probably a more basic issue.
Here is my advice if this is something you can do yourself.
Pull your spark plugs. Look for them to be all of the same shape and color. If say they all are, and one is black, that will narrow down what your issue can be.
(In the same respect that the dealer said you have a bad wiring harness, you could actually have a bad ignition wire. Make sure they are all plugged in and tight. Make sure one is not just hanging there not snapped on.
Pull the distributor cap. I recently had a sputtering issue I couldn't find then one day on my way to work my Jeep just died. It had broken the end of the rotor finally. I missed it because it was intermittent. Although, that might be a moot point if yours is newer you don't have a distributor, but you will have a coil packs I believe, so I would check them for carbon tracks. although if you had a serious misfire, it should throw a code.
Next you should have a schrader valve on the fuel rail. If you have a fuel guage you can tap into that and see what your pressure is. If you have low intermittent pressure that could make it cut out intermittently. Also take a fuel sample like in a glass jar and look for water or gunk in the fuel. That is another possibility of issues that might not throw codes.
I know I am making a lot of assumptions, but a good mechanic will check the basics before telling you your Jeep is bad. At some point when cars get too old dealerships don't want to work on them and they will take your couple of hours of labor, and push you out the door. In cases like that, I think a specialty Jeep shop or even a 4x4 shop is even a better resource. I would actually advise an auto electric shop, but I don't believe in your diagnosis. I am really thinking you need a second opinion.
Sorry for my rant, but I am pretty passionate about good auto mechanics, and I don't think they gave you a square deal. I don't want to see you spend a lot of money have it not work then be back at square one. Spend a little more money and get a better diagnoses. They are just guessing, and I am betting their wrong. Especially because they have no liability in being wrong. If they are wrong, are they going to pay for your time and money on their bad guess? I don't think so. Don't buy anything unless you are sure it is going to fix it, and if it doesn't, make them take it off or eat the rest of the repair.
it is not your fault if they don't know how to diagnose something, so you shouldn't have to pay for them to practice, It is not like going to the doctors! It is not a practice.
Good Luck! again sorry for the rant, I hope I can save you some money, and get your Jeep back on the road at the same time.
That is slightly more helpful than telling you that your Jeep is broken. At least you know the problem isn't a flat tire. :)
@ac_ Thanks for your advice.... And ur rant (honestly). The dealership didn't charge me. When I went to pick up the Jeep the customer service guy that was handling my Jeep said sorry they couldn't help, but the good news is that they weren't going to be charging me. I just laughed.
Reactions: ac_
Go through and disconnect and reconnect as many plugs as you can find. Especially anything that has been touched or replaced. A few years ago, I had a similar issue and went through this process. I'll never know the specific plug, but I'll guess that it was an o2 sensorr that I had replaced several months earlier.
More recently, I was intermittently losing the reverse lights, gas gauge and some other things. Someone suggested that I check the large connections on the firewall above the valve cover. One of the plugs was loose and the problem went away.
Had a similar issue and it took me over a month and a half to find it. The plug from the ECM that feeds 5V to the CAM and CPS sensors was unseated. I plugged it back in (maybe 1/8"), it clicked finally. That was over 20k miles ago and still running strong.
Reactions: Chris and jjvw
It's interesting that you say that, because this all started after I replaced my cps.
You aee saying that you got the plug to "click" into the cps or the plug to the ecu?
Wow... that had to have driven you crazy. Great advice though. This is something most of us wouldn't even think to check!
Go back and check your work on the CPS.
The computer is really sensitive to the sensors and the plugs aren't always the easiest to get fully seated.
The big plug that goes into the PCM was loose
I'm going to play around with the wires, but I'm guessing maybe one, or more of the pins in the plug that goes to the cps is/are loose. If not, does anyone have an answer to my original question?
Do the wires for the lockers on a Rubicon run in the engine wiring harness? I.E. If I get a used wiring harness do I have to get one from a Rubicon?
Hey, still looking for an answer as to whether the wires for the lockers on a Rubicon run in the engine wiring harness, or does anyone know where I might be able to get a wiring diagram for a 2005 rubicon?
