Yeah it's exactly that. If the road is just paved it's nice and straight. Any bump and it's like "hang on for the ride fellas".I have a 98 TJ that I just put the OME kit on - supposed to be a 2" lift but I think my shocks/springs were so worn that the end result was 3". I still have the stock tires on, have not replaced with larger tires - and I have the exact same issues as you do. Any bump or even dip/rise in the road seems to cause it to just feel like I'm on ice. ( this kit also came with the steering stabilizer )
As Jerry mentioned above, this clearly could be b/c of being " built/modified by someone who didn't know what they were doing " - but I did take my time and double/triple check everything I changed.
i was actually thinking of alignment, but when I let go of the steering wheel (as long as I don't go over anything) it _does_ stay straight, but that's probably not an accurate test.
p.s. I also added a .75 coil spacer to just the front
I just messed with my toe in and out. And still nothing.
I did tighten my steering box like a quarter turn and that helped with slack.
I then noticed my track bar isn't adjustable and my axle is about an inch and half or so not centered. So I'm replacing front and back track bar with stronger adjustable ones.
Baby steps yanno.
