Putting the servo operated one on a small timer would be perfect, full flow at start up to circulate the water through the core, then shuts off after 30 sec after startup. then just bypass it during winter months for normal operation. The Ranger vacuum controlled unit would be good as you could have it off/bypass when A/C is active.
