Jeep Build Sheet Website
Jeffreybomb
Póg mo thóin!
Chicago, IL
I just emailed Jeep in an effort to find out why they removed the build sheet finder. Hopefully, they'll get back to me. It was such a handy tool.
Does anyone know why it was removed?
Reactions: Starrs
Don't think so, they moved into Indy about a year or two ago, took over the tallest building in the city as their 2nd HQ. Gotta think the cost of living is a bit cheaper than SF
I emailed Jeep through their website and received this response:
Thank you for contacting the Jeep Customer Assistance Center.
I appreciate the time you have taken to advise of your concern. This is odd due to I was able to use the following website links to the same website which allow you to search the information with a vehicle identifcation number:
Please use one of the following links and tell me if they work:
1.https://fcacommunity.force.com/RAM/s/equipment-listing
2.https://fcacommunity.force.com/Jeep/s/article/How-do-I-get-a-vehicle-equipment-list
3.https://fcacommunity.force.com/Jeep/s/topic/0TOf1000000UXRDGA4/vehicle-information
Reactions: Miracle Jeep
Thanks for the info, just used the first link and learned mine had the Dana 44 rear axle option! Also has the Dana 30 front, what is the preferred upgrade for front axle?
Dana 30 is pretty much it for the front axle, unless you get the Rubicon. They all came with Dana 44 front and rear. The Dana 30 is plenty strong for 95% of the users though...and really a Dana 44 Rubicon axle isn't that much stronger...nearly the same externally as the Dana 30. It does have bigger inner axles and ring gear, but the tubes, knuckles, and axle outers are the same size.
