Oh
sorry didn't see the comment about the 2nd and reverse. To answer that I would say originally when I bought the jeep. I did not have an issue with 2nd and reverse. However on inspection I realized my inner boot on the shifter was completely tore out and the shift tower boot was also torn and in bad condition. Once I changed those and put the stiff outer rubber boot back on the shifter. I then had issues with 2nd staying in. I changed the rubber outer boot to a vinyl one made by a guy that makes them for jeep and it shifts like a dream now. I do have a little synchro grind from 1st to 2nd that is a separate issue but to answer your question. Once all of the proper boots were in I did have trouble with 2nd staying in but no longer have that issue with the new boot.Looks like at least a 1" drop with that box tubing stuffed in there, maybe 1.5". That's why I was asking if you were having troubles keeping 2nd and reverse from popping out.
