Installed Yukon manual hubs and the Vanco 16" Big Brake Kit
I have to get used to using them. I’d always grab the steering wheel when getting in the Jeep and I wanted to get away from that habit. Everyone seems to love them so I thought I’d try them. I replaced the factory screws with a hex head style bolt and will paint them at some point.
I really like my grab bars. Got the name brand but I probably should have gotten cheaper ones. They do not change my view outside from the drivers seat at all and make getting in/out much easier. They have never been an issue as far as getting in the way either.I have been thinking about getting some of those. How do you like them? They pretty much out of the way as far as entering and exiting? They just appear to stick out kind of far, but it's hard to tell in pics.![]()
Installed the Bartact seat covers that Cindy got me for Christmas. These are the base model style but are fine with me. I also installed seat heaters but haven’t wired them in yet. I pulled the center console to make things easier and in prep for the heater switches.
View attachment 74568View attachment 74565View attachment 74566View attachment 74567
They set up an Instagram account for it - @Savvy_GladiatorI stopped by savvy the other day. The jt they are working on is going to be at koh. They were about to drop new axles in it when I was there.
They are designed to go over your factory seat covers. My drivers side cover was in bad shape and I wanted to get rid of it to install the seat heaters. You can see some foam but I’ll try to make an adjustment after they’re broken in. If that doesn’t work I guess we’ll have to figure something out.I thought they were designed to go over the stock seat covers not wholesale replace them. I mean I would much rather that they did! But don’t you have foam sticking out in some places? It looks great in your pictures!
how did it work? dealing with the same issue on the passenger side.I weather stripped my drivers door. Has leakage puddling on the floor mat after a hard rain. Started at the bottom, then up the frount of the door the all the way around. Had about 2
Ft
of weather strip left.
Waiting for it to rain again to see if it worked.
https://www.amazon.com/gp/product/B012NMCVFE/?tag=wranglerorg-20
Wow! Nice job! And NO leaks!
Gives you time to drive it around some to make sure everything is okay before heading to Utah.
How did the driveway turn out?
