Hey guys, I’m new to this forum. In my hunt for my first Wrangler, I’ve decided on a TJ or LJ with a 4.0 and a manual transmission. Now should I pick the 5-speed NV3550 or 6-speed NSG370? What would you prefer?
If you want a 5 speed, then you won't be getting an LJ. At least not in stock form.![]()
I'm no longer a fan of manual transmissions in a Wrangler that sees tough offroad trails but I'm in agreement with Chris above on manual transmission choices. My first choice would definitely be the AX-15, with the NV3550 being in non-close second place, with the NSG370 being in a very distant third place. Not many feel the NSG370 was a good choice for a Wrangler.
I have a B&M shifter in my 04 rubi. I've had the sifter about 4 months now it is firm and gives you a pice of mind when u shift and knowing that ur in the gear you want to be in.My LJ has the NSG370 in it. I've owned it since late October and it gets driven daily. I still haven't made up my mind if I like the trans yet. It works pretty good, but the shifter is sloppy. Like I think I'm putting it in 3rd and it goes into 5th. If I take my time about shifting, I usually get it right. I haven't had it pop out of gear yet.
I'm thinking about one of those B&M shifters for it though.
Is I have started having the same problems I'm currently at 201k in my 04 rubi if I remember correctly I started having trouble right at 193k. Was there anyothere problems along with the sencronizors?My original NV3550 lasted about 193,000 miles before it started to give me trouble. 1st - 4th gear synchros were shot and it liked to pop out of 5th gear. For comparison, the original clutch was replaced at 189,000 (even though it was still in working condition). I replaced my NV3550 with a rebuilt unit after rev matching for a year. The rebuilt unit pops out of 4th on deceleration if I don't hold the shifter and pops out of 2nd in 4low unless I really pull back hard. It isn't enough of a problem to bother fixing currently, but if I had to do it again, I'd probably go with an AX15. My Jeep will never have anything besides a manual transmission. I'll probably end up ditching the NV3550 for some other manual in 10+ years when I decide to swap to something besides a 4.0L.
If I was buying a Jeep today, I'd want an AX15. But if I found the right Jeep with an NV3550, I wouldn't shy away from buying it. The NV3550 isn't as good as an AX15, but it is definitely acceptable.
Hey Chris,All things equal, the AX-15 in the earlier TJs is actually the most desirable manual transmission it would seem.
The NV3550 isn't bad (it seems to be a better choice than the NSG370), but when the NV3550 goes bad, most seem to replace it with an AX-15 because it bolts-in with no modifications, it's half the cost, parts are easy to find (and a lot less as well), and it has much more aftermarket support as well.
But if all we're talking about is the NV3550 vs the NSG370, I'd take the NV3550, as it seems to have the better reputation of the two. Of course this is just based off internet talk I've followed, so take it for what it's worth.
