New 31" General Grabber ATX
HuskerJeep
Omaha, NE
Hey everyone, I mounted up some new 31x10.5R15 General Grabber ATX on some used Ravines I came across and thought I'd share some photos since I couldn't find a whole lot while I was looking.
This is stock suspension for now, no wheel spacers. Keep in mind that according to the manufacturers specs the 31" Grabbers are actually 31" diameter wheras the BFG KO2 is about 30.5".
I haven't put any miles on them yet, so this is all just for the visual.
78082
78083
78081
With 2" of lift that will look perfect!
You'll have to let us know how you like them long term. I see you decided to go with the white lettering out.
Yeah, I really like the white letter out look personally.
As for the lift, I've actually been leaning very heavily towards H&R 1" Springs with Bilsteins or Ranchos.
Reactions: StG58
A 1" lift would look good as well!
Reactions: StG58
The H&R springs usually net about an inch and a half of lift on a normally weighted TJ. Consider putting a half inch spring spacer in the front if you are putting a winch and a fairly heavy aftermarket bumper on. Check your bump stops and set accordingly. They may be just fine, but each TJ is a little different. If you get tire rub at full lock, a washer or two on the steering stops fixes that easily. Drivers side may take one, passenger side two.
Good looking TJ! Those are my favorite factory wheels.
Reactions: HuskerJeep
