This weekend, as I was installing a new steering stabilizer, I was really able to inspect the steering components and found several issues I'd like some opinions on.
1. Looks like my tie rod has been rubbing on the drag link where it connects to the Pitman arm. I suspect it may have been bent at one time. Seems like a good time to upgrade to the ZJ Tie Rod (Moog DS1312, Moog ES3096L, Moog ES2079S).
2. The ball joint on the Drag link at the Pitman arm looks pretty bad (picture above, and another below), but the other side looks ok (second photo below). Think it's ok to just replace one side, the one that connects to the Pitman arm (Moog ES3096L)?
3. The ball joint on the Track bar also looks pretty bad. Can I just replace the ball joint, or do I need to replace the entire track bar?
4. There looks to be a leak coming off the Steering Box. Any thoughts here?
