Next project was to be today but the weather won’t cooperate. Both front fenders have this damage, which I understand is common. I impulsively- refer back to Army story! - bought aftermkt fenders, but then figured I’d try to putty OE’s up first, since they’re already damaged. The fenders were $163 for the pair and they’re not bad, new & primed black. A yard nearby wanted $150ea for used ones that would still need paint. I have until early April to return these and they pay shipping back. Need to stay under that $2K !
Finally finished putting the rear drum brakes back together after replacing the wheel cylinder. This is after replacing all the brake hard lines and front YJ hoses and new rear hose. This “simple” front hose change has blown up into all new hard lines and new rear wheel cylinders. Only thing left to do is bleed the whole system and hope for no leaks [emoji1696][emoji1696]
TJ set out in the cold today while I worked on my duramax
Sent from my SM-G950U using Tapatalk
