Hi All,
I have two questions. One regarding the NV3550 + Savvy TT combination and what noises are normal, and a second about the 15" BMB kit and revolution 1350 Dana 30 axle shafts. I've been putting more miles on the Jeep after the frame swap and just want to know if what I'm seeing / hearing is normal.
1) I've been hearing a few more noises that I think might stem from the Savvy TT. Firstly, when slowing down under 10 mph, I hear a rotational noise that can best be described as a haooomp haooomp haooomp. It is not loud and I believe it stems from the usually loud NV3550, but I just wanted to know if anybody else has that noise. Secondly, above 50 mph, if I push the clutch in or put the transmission in neutral, I hear a slight grinding noise. It sounds very much like the noise the NV3550 makes when idling in neutral. Is this noise normal? I understand that the Savvy TT mounts are going to transmit more noise and vibration, but considering that the entire transmission was just swapped into a new frame, I thought I'd make sure these noises are normal. (@jjvw, you run a similar setup to me. Normal?)
2) I also had revolution 1350 shafts installed along with my 15" BMB. I noticed today that the hardware on the BMB looks a little too machined. I've attached photos below. @mrblaine, is this ok or normal? I'm honestly not sure. It seems like a piece of the bolt has been machined down by the axle shaft.
