I did do a compression check and all were good with the exception of the #4 cylinder which was only a few pounds low. I finally pulled the valve cover and ran the engine. Noticed slop in the #1 rocker and it ended up being a bent push rod. Make sure you put something over your head to keep oil from spraying all over
