I haven’t seen any references to it on this site, so I’ll go ahead and post it.
The Mobil 1 M1-301A oil filter is a larger filter that will fit the 4.0. It has the same diameter/thread pitch as the stock size filter, but it is longer and has more volume.
It also costs the same as a normal oil filter.
A larger oil filter has two minor advantages:
1. Increased oil flow - there is a larger surface area of available filtration media, which means less pressure drop across the filter, or better oil flow
2. Increased capacity to hold removed particles - since there is a larger surface area, the filter will hold more “crap” before becoming clogged.
A third but only marginal benefit is increased oil capacity. The larger filter holds slightly more oil, which can translate to marginally lower oil temperatures due to the increased exterior surface area of the filter housing dissipating more heat. The larger capacity also means the oil goes through the engine fewer times per hour. This might increase the useful life of the oil.
Cost?
$10 at Walmart.
https://www.walmart.com/ip/Mobil-1-M1-301A-Extended-Performance-Oil-Filter/140387149
Parts that should be the same:
Mobil 1 M1-301A (also M1-301)
Motorcraft FL-1A
Fram PH8A
Wix 51515
Purolator PL30001
I’m interested to see what other people think about this.
Cost?
$10 at Walmart.
Motorcraft FL-1A
Fram PH8A
Wix 51515
Purolator PL30001
