Looks great BlackSheep- I'd love to eventually complete a full project like this...Like Mike said above, I'm trying to preserve and keep mine for many many years to come
I'm just guessing, but I don't think you read the article I linked, so I'll copy and paste a quote from it here.Stainless isn't as great as you might think...There are some inherent issues trying to form 300 series Stainless (The stuff you would want to prevent real corrosion). Basically, it would have to be fully cut, assembled and welded vs bent like most Automotive frames. That would drive the price into the unrealistic category very quickly.
You impress the hell out of me!99 New England Frame, ready for the scrap pile (drivers side lower control arm mount rotted off as well as the skid plate area on both sides):
2006 replacement frame, fresh out of the hot dip galvanize tank:
Hopefully, now New England salt proof...
Thats awesome... i wish i had thought of that! I do have a matching two piece frame that would go great with yours if you want it...99 New England Frame, ready for the scrap pile (drivers side lower control arm mount rotted off as well as the skid plate area on both sides):
I actually did read the article. It was written in 1998. I think its safe to say their ideas did not pan out.I'm just guessing, but I don't think you read the article I linked, so I'll copy and paste a quote from it here.
"Lazzari says automotive industry officials can understand how a stainless frame is lighter than one made with carbon steel and how the strength of stainless will produce a smoother ride. But one question always comes up: "(Stainless) costs so much more than carbon steel. How can you tell me it would be less expensive?"
Armco and Autokinetics think they've solved the problem by designing a frame that uses less steel, is easier to manufacture, and produces less waste. There are additional savings because stainless steel is made corrosion-resistant while carbon steel must be coated with zinc.
"We more than make up for the higher cost per pound," says Autokinetics president Bruce Emmons. "We're expecting it to be less expensive than carbon steel."
True. Never even looked at the date.I actually did read the article. It was written in 1998. I think its safe to say their ideas did not pan out.
Sandblasted, Safe-T-Capped, and undercoated by Auto Rust Technicians in Rhode Island (manufacturers of Safe T Cap). If I'm going to pay for work done on my Jeep, I'll only pay for the best. Not a single speck of rot left on my New York Jeep.
Same MO here as well. Drove up to RI and had the pros do mine. 2 1/2 years later, holding up as clean and solid as the day I left their shop.
What welder are you using? Was thinking fluxcore 145 amp would work, but I dont have alot of experience welding. So gonna need t practice before I hit install the center skid sections.View attachment 86180View attachment 86181View attachment 86182
Lol yours isn't that bad off. I don't drive this, already have the safety-caps, welder and plasma cutter. just waiting on the free time to get it done.
Just got a quote for both sides center skid sections with with rear trail arms. $3000 cut, blasted, welded and coated.Can you share a ballpark of what you paid? No worries if not, just curious.
Let us know how it goes.
Fluxcore 145a will work great... did my whole jeep with a Lincoln 140, has no issue with 1/4" stuff and bigger.... the fluxcore is way more forgiving than using argon.What welder are you using? Was thinking fluxcore 145 amp would work, but I dont have alot of experience welding. So gonna need t practice before I hit install the center skid sections.
