Hello,
I have recently started my heatercore replacement in my 2004 TJ. I am following instructions posted at: https://wranglertjforum.com/threads/how-to-replace-the-heater-core-on-a-jeep-wrangler-tj.471/ .
I am on step #19. "In the middle, just above the cylinder head. Note that this one holds the cowl plenum drain tube. The nut holding the drain tube must be removed, the cowl plenum drain removed, and then there is another nut underneath. "
I removed the 7/16 nut on top of the cowl plenum drain. but the instructions say there is another nut under the the cowl. I cannot figure out how to get the drain cowl off to get to the bolt. There is not enough room between the engine and the firewall of the jeep for me to pull it off.
Is there some kind of trick?
I can upload a video or pictures of what I am talking about.
Thanks in advance!
Matt
Thanks in advance!
Matt
