I noticed that my ARB locker compressor is puking oil out of the breather filter. Is this normal? I disconnected the airline and blew out the oil. My compressor, without the airline attached will run for about 2.6 seconds and then shut off. It will stay shut off for 45 seconds and then will run for 2.6 seconds. Is this normal or is there something wrong. It seems that it should run until I shut off the power to it.
In another issue along the same lines. I was checking to see if my Dana 30 breather line was clear. I pulled on the line and the hose fitting came out of the differential. I pushed it back in, but it seems loose. Tere isn't any threads in the differential hole that holds the breather fitting. Is that normal?
This is the breather hose fitting.
Differential breather fitting hole.
ARB compressor with oil underneath it.
Thanks,
Igoo65
Thanks,
Igoo65
