My jeeps PO installed the stinger to the rear differential and it seems to work well.
However I will read the instructions and see if I need to double check the install.
Thanks for the post Wildman !
The stinger for the stock axles seems to be better than what I have. I'm not saying it doesn't work but I have had a popping noise in my rear suspension ever since I installed it. The first time it made this pop I pulled over to make sure I hadn't broken anything. And then I've had issues with the rear of my TJ hopping when trying to climb steep hills. It can get a little hairy sometimes when it will hop and my front slides to the side. The trails it does this on are not trails you want this to happen. I'm taking the longarm kit off my TJ this summer and installing a different suspension.
