2.5 Lift for Jeep TJ $380 obo
LoKrawl
Maryland
Price
380
Lanham, MD
For sale: 2.5" OME springs (front and rear), 4 procomp boxed lower control arms, and 2 rubiconexpress rear adjustable control arms.
Will also include a pair of metalcloak adjustable bump stops and a rear sway bar with sway bar extensions attached.
If you want them you can also have the 4 OME shocks and a spare set of stock front upper control arms.
The front lower control arms will need new bushings on the axle side and the shocks are probably at the end of their life. They function but have some dents on the rear and rock rash on all of them.
I'd recommend running 33" tires or smaller with these but I ran 35's with flat fenders.
$380obo. Trades/partial-trades will be considered. Things I'm in the market for are TJ full doors, tool boxes, work bench, bench vice, chain saw, bench grinder, pressure washer, sand blaster, weed wacker, air compressor 40-80gal, roof cargo storage box, tools...
OME front coils MPN# 2932 https://www.extremeterrain.com/old-man-emu-2-front-lift-light-load-coil-springs-9706-tj.html
OME rear coils MPN# 2941 https://www.extremeterrain.com/old-man-emu-25-rear-lift-light-load-coil-springs-9706-tj.html
ProComp boxed front lower control arms MPN# 55200 https://www.extremeterrain.com/pro-comp-boxed-front-lower-control-arms-9706-tj.html
ProComp boxed rear lower control arms MPN# 55400 https://www.extremeterrain.com/pro-comp-boxed-rear-lower-control-arms-9706-tj.html
Rubicon Express rear upper adjustable control arms MPN# RE3783 http://www.rubiconexpress.com/Suspension/Rubicon-Express-Control-Arm-Rear-Adjustable-Upper-Super-Flex-TJ-LJ-ZJ-Pair-RE3783.aspx?t_c=1&t_s=101&t_pt=3158&t_pn=R/ERE3783
Located in Lanham, MD
For those that have asked how tall this kit is or what it looks like on the Jeep I've posted an image below. Keep in mind in this picture my rig has a 1" body lift so the tub will sit slightly lower if you have a stock TJ.
Post title says 2.5" and the links you provided are for the light duty. From my understanding the 2.5" is caused by running the HD coils with a TJ that is not loaded up with body armor, bumpers, winches, etc.
Can you confirm if they are Light Duty or Heavy Duty? Is there a manufacturing stamp or identifier to confirm one way or the other?
Can’t find that number. Must be an inspection number. Thanks for trying.
Sorry that’s the only one I can see that’s legible. I didn’t buy this lift kit originally but the previous owner said it’s a 2.5” OME springs. I assume it’s the lights but I’m not positive. I was under the impression the heavys were less lift but I’d have to look into it.
Well the TJ in the photo is 4700lbs if that helps predict your height. My fenders are the only aluminum, all my skids, sliders, and bumpers are steel.
Ok thanks. You’re running much bigger tires than my 31’s, so the picture is tough to compare. Seems like you’re sitting up pretty high, but must be that extra body lift throwing me off.
I’m on the fence between a simple 2” budget boost with Ranchos or to drop an extra $150 on some used OME springs like these and pair them with the Ranchos.
It’s the wife’s Jeep so the suspension lift would be overkill as she’s not huge into the off road scene. I just like the idea that’s it’s there if I need it.
You’d be miles ahead doing coils rather than a budget boost spacer
Here’s the Jeep on 33s
If you are looking to buy a new lift hit up [email protected]
He gets the best deals Teraflex kits but his prices are generally good for most brands.
I am also running 33's on OME springs. I am using the LJ/ZJ kit and also have a 1" body lift. They seem to yield consistent heights across the board. My jeep is very light right now but will be getting some armor, bumpers, and most likely a winch.
