I ordered and received my new front and rear bumpers from KD Fabworks, and while the front install was a breeze, the rear install is more complex since it ties into the two rear body mounts.
My concern is rust, since I live in New England the jeep has a bunch of rusty bolts, including these body mount bolts. Since I need to loosen or remove some of the bolts I intend to replace them, but wanted to see if anyone had a recommendation to source the bolts. I found this site which seems like a good price but would like to hear what others have done.
Also, the bushings appear to be fine but is replacing the bushings recommended since they are almost 15 years old? Is there a stock kit available that is the same quality as mopar, or better? Not looking for Daystar, Crown or Energy kind of mounts, regular stock rubber mounts? Maybe there is a complete refresh kit with stock parts (bolts and bushings) that someone may know of?
Also, would you recommend removing the bolts by hand or with an impact wrench, due to the rust?
Thanks in advance?
https://www.jeepbolts.com/collectio...y-mount-bolts-full-set-11-grade-8-beefy-bolts
Thanks in advance?
