Free length begins to matters when the shocks allow the coils to flop around. The free length matters a lot when you are moving shock mounts around and you want to better match the shock travels to the spring travels.I'm confused? Are y'all agreeing that springs are springs? Are the Rough Country springs that the previous owner installed as good as Currie's. My RC springs give me 4" lift just like Currie's.
Correct.This thread https://wranglertjforum.com/threads/who-sells-the-best-springs-for-a-4-inch-lift.19918/ asks the OP if he needs length or load capacity. People talk about how long Currie springs free length. They have to have a lower rate.
What is this based on? Do you have data?
I have a spreadsheet. Including all coils, front and rear the lightest is a 130lbs giving ~1" front lift and the heaviest is 250lbs giving ~3.75" rear lift. Neither of those can be compared to each other. Once you can group by actual lift heights, the rates become very similar to each other.
What is the rate of the standard spring?
What is the model number? I never paid close attention to the Light, Med, Heavy names. There are several OME coils from other vehicles that fit the TJ. When I was messing around with OME coils, I based any choices on rate and length.
