OP D Datman Member Joined May 15, 2019 Messages 90 Location louisiana May 16, 2019 #41 I greatly appreciate everybody’s input!
RockMyJeep New Member Joined May 16, 2019 Messages 4 Location North Idaho May 17, 2019 #42 Datman said: question, its weird that the 4wd dash lights dont come on.... Click to expand... Could be corrosion on the gauge cluster connection. Mine didn’t work for years and finally decided to last winter.
OP D Datman Member Joined May 15, 2019 Messages 90 Location louisiana May 17, 2019 #43 Welp, unfortunately the timing didnt work out as I was called out to work.....So the jeep search will have to continue at a later date...bummer
TJ2 TJ Expert Joined Dec 9, 2017 Messages 4,047 Location Texas United States May 17, 2019 #44 RockMyJeep said: Could be corrosion on the gauge cluster connection. Mine didn’t work for years and finally decided to last winter. Click to expand... 2003 does not have the 4x4 light in the dash. I believe yours is not '03. Reactions: RockMyJeep and Datman
MangoTango TJ Enthusiast Supporting Member Joined Jan 13, 2019 Messages 202 Location Orchard Park NY Jun 25, 2019 #45 lowranger said: But you said you could feel it go into 4 WD. It could be as simple as a bad bulb or loose wire. I wouldn't let that stop me from buying it at that price. Click to expand... My 4WD light burnt out a long time ago. Cheap and easy to replace with LED's. I agree I wouldn't let something that small stop me from buying it.
