I did some more measurements and calculations and I've come to the conclusion that I will need to remove nearly the entire width of the frame at the bottom for the 2.5x14 coilover to clear. I do have some strength concerns with that as well since I plan to place the air bumps in front of that C notch and the forces of winching/recovery. While possible, this is a difficult area to reinforce and to box on the inboard side with the motor mount being present and even that box would need to also then be notched to clear my upper control arm and reboxed.
To avoid that mess I decided to go with 2.0x14 coilovers in the front. Based on my approximate measurements they should be way easier to fit since they are narrower and shorter for the same amount of travel.
Like I previously mentioned, from my experience, 2.0s with DSC ride comparatively to 2.5s. When I started my build the DSCs were not available yet. The con to going with the smaller 2.0 is in something like a racing application where they will heat up and fade and the added volume of a 2.5 is needed, or on a heavy Jeep. But I suspect I've only added a few hundred pounds of sprung weight. Since I have the 2.5s in the rear, which see twice the work of the fronts, I should be in good shape. If I ever find that they're not meeting my needs I can always look into bypass shocks (although I truly don't think I ever will need them or else I'd be going down that road now).
The new coilovers will hopefully be in early next week.
