Track bar is in now, that was an old pic.
Yes Reid knuckles so I don't have steering arm adjustability. I just have steering stops and pitman to adjust.
When you tuned your test pitman did you have everything tightened down to limit slop in system?
How did you get a good accurate measurement of the demo pitman? I'm thinking caliper inside of both circles then plus 1/2 each calipered hole diameter, but that doesn't strike me as a 3 decimal measurement. Did you do something different?
You mention if the steering travel isn't perfectly balanced then you would bend the pitman or adjust steering arm. Why not just center the steering by adjusting drag link and let the steering wheel be not perfectly centered? Is there any other downside to using drag link to center steering stroke?
