To prevent the hoops from folding into the engine I am placing a spreader bar across the hoops and over the engine. The hoop I have came from Genright and is made from 0.120" wall 1-1/2" DOM with prebent ends.
To prevent any warping during welding, I welded on a temporary spreader bar between the hoops across the front of the engine. I then fully welded the hoops to the frame.
(spoiler: air bumps are happening)
I roughly mocked up the hoop spreader bar stacked on sheets of cardboard and held in place with tape to clear the supercharger and I found that the hood wouldn't close by about 1/2" due to the reinforcement down the center of the hood. So much for being easy! I'll be cutting and sliding down the center section about 1" to make room.
I want the bend in the tube to be centered over the supercharger but that places the hoop off center. I also want to keep the grill support rods (which aren't symmetrical to each other... I've been looking at them for 10 years and I never realized that...) Rather than only choosing either/or, I decided to have it all and cut the spreader bar in half to stretch it. There's not really a great place to cut it that won't waste the section so I just cut it right in the middle; I have new DOM that I'll be cutting to patch in the center section.
With the center section cut, I placed a sleeve over the 2 ends so they could slide but still be straight. I also raised the hoop up 1/2" off the supercharger to take into account the engine moving around in it's mounts.
I then notched and cut both "extensions", welded the flanges on at the table. Before welding the extensions onto the hoops and spreader I made sure both halves of the spreader were at the same angle.
I unbolted and removed both halves of the spreader and replaced the sleeve with a smaller one. I then welded on a temporary girdle to prevent movement while I worked on lowering the center.
