So I was under the Jeep today and it looks like a bit of differential oil had leaked out from around the connection to the vent tube. A little had also been blown onto the underside of the gas tank skid. A forum search told me that water in the fluid could cause this, so I pulled the plug. Although the oil is no longer honey colored (a little brown), it doesn't have any water in it and is still somewhat translucent. I figured that I would change the fluid anyway, which I have not done since my lift was installed.
Then I really looked at it and got to thinking about the pinion angle. It's a four inch lift with adjustable arms and SYE/CV driveshaft, so the pinion angle is much greater than it was when I last changed the fluid. I feel rather stupid for asking this, but because of the increased angle the fill hole is "lower". So how do I get the recommended amount of diff fluid in there? Am I overthinking it?
It's a Dana 44 rear with the OE diff cover.
