To all, I have ordered up replacement frame rails for my 2001 TJ that will go from the front control arm mount to the rear control arm mount. I am a decent welder, so I am not worried about that, and will be using cutoff disks to cut out the rusted frame rails. I also have jacks and jack stands to hold the transmission/transfer case while I have the mount removed for the replacements.
I guess my questions are for those who have done this, did you run into any issues that you had not accounted for once you got knee deep into the project, was it difficult to get it done with the brake lines right there in your way on the driver side, and lastly, how did you go about making sure that you welded the rails in the correct position so that the mount will bolt to the frame AND the transmission?
To solve the last question, I was going to tack weld the rails on both sides and then install the transmission mount and make sure everything is bolted up correctly and then finish welding the entirety of both rails. Anyway, I am open to any advice or suggestions. Thank you.
Edited for this last question- should I be worried about the frame "sagging" if I cut both sides at the same time, or should I cut one side and weld the new rail in before moving to the other side? I am just worried about the skid plate mounting holes not lining up if I do one side at a time.
