Lift Kit Advice Needed
The_Jeep's_Named_Shelia
Denver
Looking for some input. Thinking about putting a 3.5 lift on my 97 TJ 4.0 currently running 31 tires. It is mostly a weekend vehicle but driven around town a couple of times a week.
What are your thoughts on the following? What else do I need to think about? What else should I consider?
Rubicon Express 3.5" Super-Flex Short Arm Lift Kit with Twin Tube Shocks
https://www.4wheelparts.com/p/rubicon-express-3-5-super-flex-short-arm-lift-kit-with-twin-tube-shocks-re7000-3t/_/R-BKTG-RE7000-3T#qstnAns
Advance Adapters SYE & CV Drive Shaft Kit
https://www.adamsdriveshaftoffroad.com/advance-adapters-sye-kit/
Currie Antirock Front Sway Bar
https://www.extremeterrain.com/currie-antirock-front-sway-tj-ce-9900.html?utm_content=XT%20Handling%20-%20Swaybars%20and%20Disconnects%7CCurrie&T5_Var4=J103786&intl=0&utm_campaign=XTW+Wrangler+Brands+Medium+RLSA&dialogtech=ppc&utm_source=google-pla&utm_medium=shopping&T5_Var2=shopping&gclid=CjwKCAjwqZPrBRBnEiwAmNJsNkF3md4V6DqQduapivs9vu6yv0BnmUghL16PM_0jVRH0V3-BWplzTxoCPJgQAvD_BwE&gclsrc=aw.ds
Thanks in advance!
For 31" tires you might consider a simple suspension refresh, there are plenty of threads about that using Moog springs and RS5000X shocks. You don't need or probably want a lift for 31" tires, they fit stock just fine.
If you want to run bigger tires you should pick those first, it's very important for everything else.
31s can easily rub with an Antirock. Add a small body lift.
Reactions: Sancho
I would buy a set of Currie or Snergy coil sprigs, have core 4x4 build you a set of control arms that have Synergy DDB bushings in them, YJ brake hoses for the front, JKS sway bar disconnects for the front, SYE of your choice. Fox shocks for the best ride set up by @pcoplin or a set of rancho RS5000 shocks, Tom woods Drive shafts, I would do the ZJ steering, this would be a good balanced system and allows you to do it in stages.
The idea is t
What size shocks would I need for the 3.5 lift? For a TJ it seems I can only find shocks for 2-3" & 4-5".
Choose shocks by their compressed and extended lengths. You need the ones that fit your setup. Meaning that you will need to measure your Jeep's travels and understand how to set the bump stops.
Reactions: fuse and tworley
I echo the 4" lift for 33s. Easiest way to measure for shocks is to measure from the top shock mount to the bottom mount, as well as the distance between the bumpstop cup and axle pad, and subtracting the two numbers will give you the shock length you need.
So for instance, if your first number was 15" and your second was 5", you know your compressed shock length is 10". That will narrow your search to a shock that will fit the compressed length.
I wouldn't run a Rubicon Express lift, not after seeing what happened to the bushings on @Alex01 Rubicon Express control arms in short order. Not to mention that the Rubicon Express customer service doesn't seem to want to warranty them (Alex got lucky).
So aside from that lift, I like the rest of your plans ;)
Reactions: Alex01
Any recommendations on an alternative?
Reactions: Alex01
Thanks in advance!
Sounds just like my jeep v01. I would highly recommend skipping on the RE kit.
What size tires do you ultimately want to run? If 33s I would go for a kit such as the OME ultimate kit. (best thing is you could most likely skip on the sye)
For 35s I would run https://www.currieenterprises.com/CE-9801HLS $2,450
If you account that it comes with a antirock and body lift you're about in the same ball park.
If you're already going with the Currie Antirock (a fine choice), you could get one of the Currie 4" lifts, or get some 4" Currie springs, shocks of your choice (Rancho RS5000X shocks are great), and Savvy control arms (my favorite).
Essentially that's piecing together your own lift, but that's always the way I do it.
What are your thoughts on this Build Your Own Lift (BYOL)? What am I missing? What don't I need?
-Currie Coil Springs 4"
-Rancho RS5000x Shocks
-Currie Bump Stops (Front & Rear)
-Advance Adapters SYE & CV Drive Shaft Kit
-Currie Antirock Front Swaybar
-Break line Extension
-Core 4x4 Control Arm Set (Tier 2)
-Core 4x4 Adjustable Front Track Bar (Tier 3)
-Core 4x4 Adjustable Rear Track Bar (Tier 3)
-Currie Rear Sway Bar Extended End Links
-JKS Rear Track Bar Relocation
Your kit comes to $2,547, not including the shocks and sye for $685 since you need them regardless.
I would argue the Currie kit I linked in my previous post is better built and roughly $100 less.
Also, check out Tom woods for the driveshaft/SYE. They are a fantastic company to work with.
You could also use stock YJ brake lines to save money. (they are longer)
Edit: I posted the no springs kit earlier. The correct one is https://www.currieenterprises.com/CE-9801H which is $150 more but still a better kit
Personally, I would opt for the kit one tier up for $100 more that includes double adjustable uppers. https://www.currieenterprises.com/CE-9801HS
That said for 33's you don't need a 4-inch lift +1.25 bl. You could get away with https://dpgoffroad.com/product/old-man-emu-ultimate-tjlj-wrangler-kit/
That kit is only $1,500 and you likely wouldn't need an SYE and it comes with shocks.
If you see yourself moving to 35s one day though it's best to buy once cry once I suppose. It's your money spend it as you wish.
Take a look at @JMT, @bobthetj03, and many others with similar setups. @JMT's rig did amazing in Moab and @bobthetj03 has been over the Rubicon, Moab, and many other trails.
