Should I even consider buying an 05/06 TJ?
Isn't it an easy fix anyway?
If you just stick with 03-04 you don't even have to research this question, already a win.
There are more things fixed and updated on a 05/06 than there are new problems added.
I can't think of anything fixed or updated on the 05/06 that was a problem in 03/04.
I think you are confusing the Ford Pinto gas tank and the GM truck gas tank where NBC rigged the tank to explode on impact. Nobody had to fake the Pinto gas tank problem.
It is only overblown if you are not having transmission trouble or replacing an OPDA or even worse a camshaft.
Look over there everybody, someone is building a Dana 35
Somebody is looking for a Jeep and asks should I get one with a Dana 35 or Dana 44, what would you tell them?
It's a good analogy.
I mean, it's a cute little "in joke" but you passed up an opportunity to help the OP pick out a nice Jeep which is kinda why we're here right?
I might not tell them what you think
Like just about everything else in life, depends on a whole lotta factors
I’m pretty sure that wranglerfix.com has a pcm that they manufacture from a reverse engineered pcm that should fix the transmission shift issues on this year range. I also hear people having luck with putting in a new odpa that crown makes. If this is the case I don’t see the problem. Also my 2005 is still running without issues. Obviously if you want a rubicon or a lj you don’t really have a option and have to buy in this year range.
So you're just trolling? Why not try to help somebody out, you probably have something useful to add.
you seem easily agitated, shame, but to your point I certainly thought my post was useful; say the numbers 35 in any context not describing a tire size & the internet zombies descend en masse to tell you you're crazy to even consider putting a dime in one which is folly, in my experience. Did you miss that parallel?
How many of you know about the Ford Pinto gas tank blowing up if they get bumped in the rear end? If you are old enough to know what a Pinto is then you heard this. . . .
How about the Corvair?
A good college friend had a Pinto. It didn't blow up, but it did catch fire one night. He never figured out the cause, he just fixed the wiring enough to get it running and drove it for another six months with a burned out interior.
The first car I purchased on my own was a '65 Corvair that I bought for $500 in 1969. With good tires and shocks it was competitive with the Porches of the day on the roads up and back from the SoCal mountain resorts. I sold it for $650 two years later to a guy who didn't want the car, he wanted the engine and transmission for a dune buggy.
My view is that rather than try to find a particular model year, find the best example of the vehicle you want regardless of year and then analyze whether there are any known issues with that model year and how those issues can be resolved. Factor the cost to resolve those issues into the purchase offer.
In the case of 05/06 Wranglers there is a known issue with the OPDA installed within a particular time frame during the total production run for those years. There are few reports of problem OPDA units for Wranglers produced outside that time frame. The fix is to replace the bad OPDA with the aftermarket unit from Crown while retaining the original OEM sensor; the cost is just over $100. Easy, peasy.
The automatic transmission issue affects a small percentage of 05/06 Wranglers. It is caused by a failure in the PCM. If the problem manifests, which is by no means likely, the fix is to replace the PCM, which can cost $1,200-$1,400, admittedly expensive, and it also may be impossible to find one because new units have been discontinued. However, the PCM can be replaced with a re-programmed unit from certain other Chrysler vehicles for a cost of about $600. Problem solved.
Bottom line, work the price of a 05/06 Wrangler with automatic down $700-$1,000 and you can fix the alleged "defects" in those model years with the money you didn't pay the seller in the statistically unlikely event that those "defects" ever manifest.
Reactions: DrDmoney
How many of you know about the Ford Pinto gas tank blowing up if they get bumped in the rear end? If you are old enough to know what a Pinto is then you heard this. Even showed it on TV! (Had to use explosive charge to get the footage.) Or how about the Chevy 10 bolt rear axle falling out when you go around the corner? Had that on TV too. (Had to pull the C-clips out to get the footage.) Or how about the.....
It's a bunch of bullshit! We used Pintos in the demolition derby for Christ's sake. (4 cyl division.) Never I repeat Never had any blow up.
There are more things fixed and updated on a 05/06 than there are new problems added. Heater works. How's your 97 doing? And that 97 rarely had a heater issue. The internet is mostly a pack of fools repeating what another fool said. Magazines aren't much better. Without a headline to grab your attention they just sit on the rack. Buy the TJ that YOU want. Don't worry about the Scare Of The Month headlines. You do you. Any problem with your specific Jeep can be fixed. Thanks for your question.
Yep. I had a pinto. 😂 Never blew up. Probably still going strong somewhere. You win for bringing up a Pinto for the first bbn time on this forum. @Chrishe needs an award😁
I thought it was a good analogy, that's why I said "It's a good analogy"
I think somebody new to wranglers has no idea what it means. That's why I pushed for an answer so I the OP could understand where you are coming from or what you are trying to say. The people that understand the whole Dana 35 issue don't really need somebody telling them which Wrangler to look for.
There is also the gas fill issue on the 05-06, forgot about that one.
Here's my take. I like wranglers. Don't care which one. I have an 06 Rubi. I love it. I work on it. Everyone here works on theirs whether it's modifying or repairing. Mine is basically stock. Never been abused. I'm chasing vibes, locker actuator leaks in rear, check engine stays on, but it only has 90k on it and no engine issues. I like the 6 speed. That's why I bought it. If you buy one you're gonna spend money and time on it. Lots of both. Just find one you like and get it. We'll try to help you fix it along the way and keep it going. Three things that are not cheap : 1 racing
2 boats
3 Jeeps
Reactions: duncanator
you're right, I was only addressing those that would know the Dana 35 'stuff' & why it might be relevant here. My apologies
When you've got nothing you start yelling and calling names, that's how it works on the playground right?
I'm mentally exhausted from trying to defend 05/06 models. If you heard it on the internet, it must be true.
Reactions: reddvltj
