1st i have a 2000 tj 4.0 automatic trans. Heres the story. I recently installed front fenders and rear side panel armour and fenders. I had to remove the battery to access mounting bolts. I also had to remove tail lights, and front signal lights. The new fenders have 2 wire leds in them, which i will wire in later. After i thought i was done i was going to move jeep out of my garage, it wouldn't start. It always fires right up. It would crank but not fire. Couldnt here feul pump activate or anything. After about 15 seconds the odometer read no bus. I know i somehow caused this issue. What did i do to cause this? I think its related to SKIM? PCM? Ive got a refurbished ecm on the way. My second question : if my pcm is bad or needs to be reflashed, how do prevent this from happening with the new pcm? Thanks for any help.
