Do I need an alignment after replacing control arms?
WyoJeep
Wyoming
Been searching the threads, but I'm seeing mixed answers. Is it necessary (must do immediately) to have a front end alignment after replacing upper and lower front control arms?
I just did a driveway alignment recently after replacing most of the steering components. I guess what I'm wondering is will replacing the control arms alter the alignment? I thought they maintained the axle position. No?
If your steering wheel moves you'll need to adjust toe-in and drag link length.
Camber won't change.
Caster won't change if the arms are same length as OE.
