So to start out, Im no stranger to Jeeps and automotive work in general but after a few days of scratching my head, taking measurements and writing down endless note... Ive come to the conclusion that I need your help to figure out the best solution to my issue with my suspension question.
I have an 03 Rubicon with Teraflex's first generation 4" lift kit. These had the arms that were prone to bushing failures due to lack of grease fittings on the bushing ends and instead they placed the zerks on the mid sections where the arms would twist. This bit of info is probably not needed but wanted to include it.
I also have 33" tires on factory Moab wheels
I have upgraded my shocks to Bilstein 5100's, (front 24-188180 and rear 33-185514) due to the ones installed by the PO were blown out and had boots on them so up until now I had no idea that they were bottoming out.
These shocks have the following claimed measurements. Front 24.63 EXT / 14.98 COM / 9.65 TRAVEL Rear 25" EXT / 15.41 COM / 9.59 TRAVEL
The stock teraflex lift had the PO install the 2.5" bump extensions in the rear on the upper portion chassis side between the upper spring seat and jounce cup. This 2.5" figure is inline with all the research ive done when it came down to required minimum bump stops for a 4" lift kit install. Also to mention is that without the springs and shocks, i make no contact with any other components under the chassis and have clearance with the tank, track bar and other components.
Now with the new shocks installed in the rear, I have 5" of shock shaft exposed at ride height but when i do a driveway flex ive noticed that the shocks will bottom out before I am remotely close to making contact with the bump stops. As mentioned prior, i have 2.5" of bump extension already installed in the rear. For me to close the gap in between my bump stops, id have to install an additional 2.5" of additional bump extension in order for the bump to make proper contact with the bump stops and not ruin my new shocks.
Is this correct???
As it sits, ride height i have 5" of shock shaft showing.
At ride height i have 7.25" of clearance from the jounce cup to the spring pad with the 2.5" bump extensions in place.
At ride height I have 7.8" of gap between my 33's and the stock rubi fenders.
The shock from eye to eye while at this ride height was 21".
The spring height was 14" at ride height.
(Just a note, all these numbers are related so when im parked on a more level surface, the numbers all move up or down respectively. IE; the springs today were more around 12.75 on a more level lot.)
All measurements were taken with the Jeep unloaded. Soft top on, rear seat removed and no spare.
I appreciate any and all help that contributes to finding a proper solution. This jeep is bother my daily, trail rig and cross country toy.
Its served me well when stock and is still serving missions honorably. I would like to keep her that way.
Cheers!!
Josh
Is this correct???
Cheers!!
Josh
