I just bought a 2006 Rubicon. The automatic transmission has a rough 1-2 upshift when cold. Fluid is full and looks good. Wondering if I should take it to a shop? or the Dealer? Or is there some easy adjustment? Anything is appreciated. Thanks
Exactly.This issue is typically caused by the PCM in 05-06 TJs. This thread may be helpful for you:
https://wranglertjforum.com/threads/05-06-pcm-issue-is-solved.21699/
Get on tougher rock crawling trails and you'd likely find yourself to be the only one running a manual transmission. Which is why I did a conversion from my original TJ's manual transmission to the 32RH automatic. My present 42RLE transmission is doing just fine on such trails.get rid of the shitty automatic transmission and get a manual transmission
Thank you!This issue is typically caused by the PCM in 05-06 TJs. This thread may be helpful for you:
