1) What is the TOTAL weight of your Jeep?
2) How long have you owned your Jeep?
3) What is your tire size?
4) Anything else worth knowing?
In no particular order:
2006 Jeep Wrangler Unlimited Rubicon AT w/ Hardtop
5" total lift, long arm suspension
Currie Correctlync steering
Currie Anti-Rock
35" tires/aluminum wheels
Rockhard 4x4 front bumper with 8500# winch with steel cable
Rockhard 4x4 rear bumper with tire carrier and jerry can mounts
Shrockworks sliders
Yukon Manual Hubs
Vanco 16" BBK
Rubi-Crawler underdrive
Vehicle purchased June 2017
Published curb weight with hardtop - 4,012 lbs. (all fluids, full tank of fuel - no driver, passengers or gear)
Actual weight as currently modified, with driver and full tank of fuel
but no gear - 4,880 lbs. scale weight less 185 lbs. for driver
= 4695 lbs. (weighed at CAT scale, 7/19/19)
Front Axle Weight w/ driver - 2180 lbs.
Rear Axle Weight w/ driver - 2700 lbs.
Gross weight as currently modified, with driver and full tank of fuel
fully loaded with gear, spares, tools, food, ice, extra fuel and water, etc. for extended trip -
5340 lbs. (weighed at CAT scale, 7/11/19)
Rear Axle Weight w/driver - 3160 lbs.
Calculated weight of modifications - 683 lbs. (4695 - 4012)
Approximate weight of gear, spares, tools, extra fuel and water, food, ice, etc. when fully loaded - 460 lbs. (5340-4880)
How the jeep looked 7/12/19, the morning after it was weighed fully loaded at the beginning of a week-long trip:
