2001 sport
I put the hardtop on a few weeks ago and now the weather's turn cold I found my rear defroster is not working.
the rear defroster button just pops back into its original position when I press it and the light in the switch is not working. if I recall correctly when you press the button for rear defrost the button stayed down for about 10 minutes and then it auto turned off.
I suspected the plug where it goes from the wiring harness into the hardtop because the rear wiper was giving me some problems as well.
Last night I pulled the plug out of the hardtop to access it better and was able to plug the wiring harness into it much better and secure than it was. Now the rear wipers are working again.
However the rear defrost is still not.
I checked the fuse behind the glove box and it was okay, I did not find a relay for it under the hood or anywhere else unless it's labeled differently.
is there a relay for the rear defrost I can check somewhere?
Can someone start me in the right direction to finding my problem?
I checked the tabs that plug into the rear defroster on the rear window as well and they are secure.
Thank you
Thank you
