Axle torque specs Dana 30/35
ErikOffroad
Rochester N.Y.
Is there a wright up that would have specs for the axles. I’m doing lockers and a regear. Dana 30 / super 35 build. Need to know ring gear bolt torque. Also the torque for the carrier bolts. Backlash recommendations for a 5.13 gear ratio. Rolling resistance set with the crush sleeve on the pinion and resistance with the shims in the carrier.
This will get you started. IDK where to get info for the S35.
https://www.crawlpedia.com/ring_pinion_setup.htm
