Driving my lifted Rubicon in Colorado this Summer, I have learned the value of front sway bar disconnects. Pulling them really helps tame a rough trail or road. The back end still feels stiff as a board. Do rear disconnects have a similar effect?
This shows my TJ on an uneven trail with its factory rear antiswaybar connected. You can see it flexes pretty well.Thanks for the information.
It's only determined by shock travel if the shock length is correct. I consider usable flex to be that which when the tire still has enough downward force on it so the tire won't spin ineffectively in the air or when barely touching the surface without enough traction to keep you moving.The rear sway bar is not restricting suspension travel. If anything, it would work even better with a softer, tunable front sway bar.
This vague term "usable flex" is the amount of flex ultimately determined by the shock travel. If something is limiting the travel allowed by the shock, identify what it is and decide what to do about it.
what i Get from this thread is NO disconnect sway bar. my ? then, is there any reason to upgrade the rear sway bar? or is there even a upgraded sway bar for the rear? i really didn't see anything online that looks like a upgrade other then disconnects. so does that mean the factory rear sway bar is good to go on a 3.5" lift?
my rear end was making bad whining sounds, so when i did the fluid change i saw crazy amounts of metal. now I'm getting ready to do some rear end upgrades, (ill take all the suggestions you got)
my laundry list as of now is, adjustable control arms upper/lower. adjustable trac bar, not sure if I'm gonna go dana44
or just a rebuild and locker for the 35.
any thoughts would be appreciated![]()
How's the Antirock behave on the street? It seems like it wouldn't be nearly as good at preventing body roll as the factory bar, but how "bad" is it?
I'm guessing it is just a matter of getting used to how the Jeep moves in a corner. How stiff is it in the stiffest position compared to the stock antisway bar?Long story short, it’s great. I’ve run it on a few different positions, starting out with it at the stiffest setting. After having it almost a year now I find myself running it on the second softest setting with no plans of readjusting it anytime soon.
