Saw this mess on LiteBrite. At least Brittney is closer to the right idea than the rest. Who wants to untangle?
That was a cluster flop of the highest order. The had a soft shackle and yet kept adding crap on there. A tree saver and one shackle and you are good to go.
To be fair, the one guy was threatening to kill anyone else with a better idea.
I am working on a job this week performing load tests. We are putting vertical and horizontal pressure on I beams that are varying depths in the ground for solar panels. Our lateral test connections go; beam clamp, shackle, hydraulic jack, shackle, another hydraulic jack, shackle, to a bigger shackle, dynamometer, shackle, chain, shackle, beam clamp. Upwards of 10k of pressure
I'm sitting far away as possible, though after 80 tests I'm pretty sure our connections are far from failing
Their name should be banned from hereHire the litebrite crew and see how long until they blame your installs while they use that Factor55 nonsense.
It is harder to be sane if you never have a comparison to something not sane.Their name should be banned from here
What is that everyone has the hate for the Factor 55, I have Flatlink E and it has worked well for me ??
