Rotopax fuel jugs
Have you considered the Genright tank?
Much easier to use. Just install and forget it exists. Use the extended range every time you drive.
https://genright.com/products/jeep-tj-lj-extended-range-gas-tank-skid-plate-24-5-gal.html
Alternatively, depending on how your tire carrier is built, you can use the Rock Hard jerry can mounts. They hold the can above the taillights, and are compatible with one jerry can each or two rotopax each.
Another alternative is Morryde Jerry can mounts. I don't think they're Rotopax compatible though.
I switched from the single 4.5 gal to the 2 x 2gal rotopax but still inside for now.View attachment 127340
I ordered the 2.5 gallon RotoPax. Seems like I’m always about 5 gallons short on some of the longer runs. I hate staying at camp when I could be wheelin because I’m worried about not having enough ⛽
Reactions: DrDmoney
Rotpax are made about a block from my work. I would not mount them on the drivers side but passenger side would be more acceptable IMHO.
Reactions: DrDmoney
Thinking about a set of MOR/Ryde tailgate hinges with a Risk Racing 3 gallon gas can & carrier mounted to the tailgate hinge. My spare is a little over 31" & has been fine on the stock tailgate with good snubbers. Thinkin there might be 6" between the tire & the taillight. Should be a pretty easy bracket to fab. And could be secured on top with a strap thru the spare tire.
https://riskracing.com/products/ez3-utility-jug-hose-bender-spout-combo-pack
