Jeep cranks over but no start.
Fuel pressure is good. Removed boot off of the throttle body and sprayed starter fluid. Still no start. Checked for spark at coil rail. All had spark but 1. Replaced coil rail and spark plugs. Also replaced crank case sensor. Still cranks over good but no start. Im starting to think its my ecu. Removed negative wire from battery to reset and still no start. Only had 1 engine code before starting on this p1297 map sensor code. Which was first thing i replaced. Now i longer get codes. Any suggestions?
One other small detail. I drove jeep to airport and never had issue with this before not starting, i get back a week later and the park place said they had to jump my jeep but couldnt get it started.
