What mods should my new Tj get!?
Kendall308
Ozark, MO, United States
Just bought my first Tj. Already have a 95 Grand Cherokee Laredo but it's not really worth putting the money into. So it's my Fiancé's daily for now.
Curious what mods I should put on in the next few months.
1998 jeep wrangler sahara.
I plan on doing all bodywork and painting back to factory green.
Already have a soft top and a matching tan bikini top and Matching full doors.
Definately thinking about a full set of tube fenders and a wicked front bumper. Probably a light bar or three. Maybe a winch.
But I would like to know what the community thinks!
Sent from my SAMSUNG-SM-G935A using Tapatalk
Welcome to the forum first of all. What is your planned use for it? At a minimum all fluids, belt, full tune up if not recent, suspension check out and replace as necessary and lube, brake check. Basically make sure it is sound mechanically before dumping any money on modifications.
The first thing I always think of is the right tires for your intended use, the appropriate size lift, and a winch!
Reactions: JP98
I'm with Chris. Take the time to think through how you are planning to use your new TJ. Then go for the things that will help it preform to your expectations. The right tires, a little lift and a winch will get you a long way.
Reactions: Stinger
I like the tires on it. Hate the wheels though. And it has a 3 inch lift already but I think I will eventually end up with a 6 inch longarm.
And definately a winch. Had a 5000 warn on my Frontier and it was a lifesaver more than once
do lots of home work before any mod of any kind save money in long run and keep from buying junk.example---my first lift was a rough country 6" short arm.pure junk and worst ride ever in anything ive ever lifted..read read and read some more.listen to the ones that have already done that.
Carpeting (or better yet a Bedrug kit). Your jeep will get really hot and loud in the summer time if you don't have some insulation and another barrier between you and Jeep's tub. And definitely a spare tire.
