I just completed my Savvy Body Lift. I don't know if this has been mentioned yet, but when you do the rubber isolators below the grille, you'll need to take out the headlights to run the bolt through the hole and screw it into the spacer provided in the savvy kit. On the end of the rubber isolator, there is a nipple. You will have to trim the nipple before fitting it into the spacer, otherwise it will interfere with the bolt coming through the spacer.
One final thing. Make sure you unscrew the fuel filler. When you do the body lift, the body will pull the rubber filler hose, and you could possibly break something. When you do that, and the body lift is complete, you'll notice that there is a gap, and the filler won't mate up. You either have to loosen the hose and adjust it, or do like I did and cut it off (I got tired of trying adjust it), and buy a new hose. I got a hose on Amazon that happened to be longer than stock for the TJ. It worked out perfectly. Here's a link below to the one I got
https://www.amazon.com/dp/B000FPXUKM/?tag=wranglerorg-20
