What is the ratio in 4 high with the 241 and what is the ratio in 4lo with the 231?Because 2.72:1 is the perfect reduction in sand and mud....
Just like 4:1 is the perfect reduction on the rocks....
and 4HI is perfect on a trail.....
otherwise why have a 2 speed transfer case ??
if you want to compromize in mud and sand, have at 'er.
me, I see no need for 4:1 cuz I never need to climb a waterfall.
But I do cross a lot of sandy beaches. and 2.72 would be perfect.
I really wish people would listen to what the guy posting is asking and give a truthful answer rather than defending their choices at all costs. Jeep makes 2 transfer cases for a reason. Neither one is inferior or better than the other but each is designed for a specific use. Pick the best one for your wheeling.
On the Dana 44 front axle, the reason it is on the Rubi is cuz all locked up crawling over rocks it is possible to send all the torque to one front tire. The reason nothing else comes with matching front and rear axles is cuz regular 4x4s..... since they were first made only send all the torque to the rear axle in 2WD. In 4WD most every 4x4 out there sends 50% of the torque to the front axle in 4WD. Hence the Dana 35/Dana 30, Dana 60/Dana 44, Dana 70/Dana 60 in virtually every 4x4 for the past 60 years.
Rock crawling comes with some specific loads not common in any other 4 wheeling.
