Good point . I guess I’m thinking stock to stock.Unless your 231 has 4:1 low range...
I also think anyone can/ should build for their terrain if needed....not on my or anyone’s mandate .
Why 4.10?
It’s 4.10:1 on all RubiconsI thought 4.10 was the stock differential gearing on late Rubicons.
I'm just starting to learn about re-gearing; I'd appreciate a link to a good write up if anyone has one.
The appropriate gearing has everything to do with the tire size and transmission. Whatever a Rubicon is does not matter, which I'll say is true for anything about how you want to build your Jeep.
I may be a smart ass, but this time, what did I do?Apologies, I 100% thought JMT was being a smart ass This is on me.
Yes, regear at the same time as lockers. With 33’s and the NSG370 you’ll want 4.56 gears. If you are ever contemplating 35’s, go with 4.88. I vote for Eaton E-Lockers front and rear if you want to be closest to a Rubicon. The good thing is you can run them in 2WD, 4wdH and 4wdL. But, since you live in SA, I know where you wheel, used to live there. Hidden Falls, Wolf Caves, a few others at times, you hardly ever see snow and ice, so you could run a PowerTrax No Slip Lunchbox up front. It’s an automatic locker, ~400 and you can DIY before or after the regear And save some coin if that’s an issue. They are invisible in 2WD.I appreciate all the comments. I plan to use the Jeep on mountain trails, no true rock crawling, sand or mud. Just steep climbs, occasional stream crossings, and very rough roads.
It's on 33" tires which is as big as I want to go.
Sounds like I'm good with the 231 T-case and Dana 30 upfront.
I'll add the lockers for sure. I suppose that would be the time to re-gear the differentials? Front and rear diffs have the same gear ratios, right? So I could go from stock 3.73 to 4.10 in both?
You can’t really go wrong with either ARB or Eaton E Lockers.I live in SA, but the Jeep is going to Colorado next month where it will live. Most of its trail-time will be in the San Juans. I bought it to get me to altitude and remote places the Explorers and RVs can't go.
I've looked a bit at the ARB and Eaton lockers; who sells the differential re-gear sets?
This. The steeper 241 transfer case has zero downsides if you've got a manual transmission. Too short of gearing? You can take off in 6th. Turns out 6th in 4lo is right between first and second in 4hi, at least with the 6 speed like the OP has.
I can say from experience that having the 4:1 and a 6 speed and properly geared axles for your tires makes one hell of a versatile rig. I've been to the Outer Banks and driven to Carova, I've done mud, done rocks, done full throttle hill climbs. It's the best combo for a stick shift.
I can see where it would be super annoying in an auto, though. Me, I just decide essentially what ratio I want to take off in when I'm crawling and that's the gear I use...
For example, I was doing a smooth, but very steep, hill climb on my last outing. 1st gear in high (I'm geared 5.13 on 37s) would bog just before cresting, using all the run up space I had available to me. 4th gear in low got me to the crest. Then I went home and bought a supercharger lol
It doesn’t matter, 456 either way.So with the NSG370 6 speed and 33" tires, what are some appropriate gearing matches with each transfer case?
If I stick with the 231, get 4.56 gears?
If I change to the 241, what gears should be in the differentials?
