- Joined
- Sep 7, 2016
- Messages
- 1
I have a very high garage and want to install a manual hoist for my hard top to store all Summer.
Please recommend brands that you like.
How much does the hard top on an '04 Wrangler X weigh? I'm wondering if my wife and I can take it off at an RV park and put on a bikini top, then put the hard top back on when we are ready to travel again.
Is it possible to leave a bikini type top/cover on the Jeep all the time? I mean, can we put the hard top back on with the bikini top on?
I'm not familiar with the "Spiderweb Shade". Where do I look?I'm not 100% sure but I want to say it's around 150 lbs.
My wife and I can take ours off by ourselves, but it's REALLY awkward due to the size, you have to be super careful.
If the bikini top doesn't have a frame (which I don't believe it does), then yes, you can leave it on the entire time, even with the hard top. We do the same thing with our Spiderweb Shade.
I don't think I have enough room in my garage for a lift. I think it would hang down far enough that I would walk into it every time I wandered around the garage. I have to explore more options and get creative.Ditto on what Chris said. My wife and I took it off the first time. It's heavy and the weight is very un-evenly distributed (like a large old cathode ray tube TV). I was OK with it. But, I'm 6' 2" and 200 lbs. My wife is 5' 4". She's in quite good shape, but it honestly scared her. She didn't feel she had good control and really didn't like it. If you do take it off by hand, after you unbolt the 6 nuts and bolts (you do still have 6, don't you ;-) and unplug the windshield washer wiring and hose, lift the rear hatch and walk it off to the back over the spare tire. Again, be careful. You drop it and you can injure yourself and/or damage the roof. I got a hoist the very next season.
BTW - I made a plywood platform with rollers to store it on. The doors rest on it under the top. I'm really happy I did this. There are also after-market top carts. When you store the doors make sure you pad well between. If you have old patio furniture cushions, they would be good. You don't want to dent / crease the bottom door from a hinge from the top one.
Good luck.
The hardtop weighs 120lb. I’ve removed it several times with my two 13 year olds several times, including at Elephant Hill in Moab.How much does the hard top on an '04 Wrangler X weigh? I'm wondering if my wife and I can take it off at an RV park and put on a bikini top, then put the hard top back on when we are ready to travel again.
I have the Harken Hoist. It has four attachment points, so it won’t rotate. I do it manually, which is no problem. I’ve used it on a 10 foot garage and presently an 8 foot. Never had a problem.I have a very high garage and want to install a manual hoist for my hard top to store all Summer.
I am looking at getting the Harken hoist and wondering how hard it is to pull to get it off the Jeep.
If I read this right it has a 4:1 mechanical advantage. If the top is 150lbs that means the pull is around 37.5 lbs of force.
