Currie bumpers
Yep, they are darn nice, bet you could have one made up at a good welding shop, they don't "appear" to be that complicated.
They have a nice taper on the underside, which when combined with the angles of the face of the bumper, probably makes it a little more difficult to pull off properly. I had one shop give me a quote of just under $900. Ouch!
That's not winch ready, those mounting bolt holes are spaced too far apart... winch mounting bolt holes are only 10" apart. That is only ready for a winch mounting plate as would be nearly any bumper.
I was just going off what John says in the video...
Edit: Measured the pre-drilled holes on my Currie V-bumper. Winch ready at 10" X 4 1/2".
Currie front with added plate and winch. Also Currie rear before I painted it.
Dredging up old goodies again.
I have both the featured Currie front with tall "hood hoop" (Option 4 in the video) and flat tow setup (minus the actual tow bar), and the Currie rear tire carrier bumper. Don't guess the other hoops will be available other than used.
Reactions: DougyintheBushies
Where's the pics?
Still working on getting clearance for a passenger side Rock Hard gas can carrier.
Pivot on the Currie is too close to the tub for RH GCC
Not the 'V' version but Currie just the same. Not a huge fan of the hood hoop but getting used to it. I actually like it better with 2 hoops.. the other being the winch guard.
This is the 54" version which I prefer for fender protection. More brush than rocks.
