You'd have to have separate steps mounted to the frame.Thanks C.J.! I have not located any with a step tube that appears to be any lower than the one pictured.
Body mounted is a bad choice. The strongest and best way is through mounted on the inside of the tub, then nutserts where there is a blind hole. What holds the weight of your transmission and skid plate?Would it be possible to affix a rocker guard secured with the body mounts and, also, a step secured to the same body mounts? Seems possible to me but I'm not sure.
The only reason I don't care for the nutserts is having to buy the tool to install them. I don't mind drilling the holes in the tube for fasteners but, for myself, a nut and bolt and be fine. Thanks!Also I think most will use nutserts in the body to hold it. You could just use a nut and washer on the inside of the tub if you don't like nutserts. But I think you mean you don't want any fastener through the tub to attach the guard.
When I needed some 1/4 X 20 nutserts, Ace Hardware had the kit: a 5/16 coupler nut, a 1/4 X 20 X 2" Cap screw, and an Allen Wrench to fit it.The only reason I don't care for the nutserts is having to buy the tool to install them.
