MountaineerTom
LJ Enthusiast, Retired USAF Weapons Loader
I was planning on using epoxy with some dry wall mesh tape behind my door panel cracks. Is the aluminum needed for support/rigidity?
I would love it if someone could share which particular SEM primer they used. There are two, Sand Free and Plastic Adhesion.
Thanks for this Tom. I just received my Camel paint but after looking through your post, it looks like my color code for Camel is a different formula from what I purchased. I’ll be calling SEM shortly to see if they can make hell me find my formula as it looks like it may have been discontinued from mass production.According to a PDF file I came across on the SEM site, it says Khaki Color Coat 15833 is for my Khaki interior.
The way I got to this is my build sheet says J3 is my interior code.
If you go to their site click resources, scroll down to Formulas and click the learn more button, then scroll down to Trim Code Formulas and type your year in. It will bring up the PDF file. It says J3 is Khaki and the formula is 5545.
Then if you go to their color cards (right above where you put the year in for formulas) and select color coat color cards, it will show a couple PDF's to open. For mine it was on the second PDF. That file showed formula 5545 is 15833. On the card it looks darker, but I know it can be misleading. I'm going to get a can and see how well it matches.
https://www.amazon.com/gp/product/B00B3HXUIS/?tag=wranglerorg-20
SandFree
Please let us know the result. I did the same thing and identified 5020 as the color i need. I did a retailer search on the SEM website and only 2 in the S. Louisiana area will mix and put in a can. One wanted $40 /can and the other $60. If you find someone that can mix and ship for half of that, i would be happy.
Thanks! I should have asked this too, do I need to rough up the trim pieces, or will the adhesion promoter alone be sufficient?I've not painted any exterior pieces, but I would think that's all you would need.
When I did my flares, I scuffed em with a green scotch bright to smooth em out and give the paint some "tooth" then I cleaned them real well with dishsoap (an excellent degreaser) and let them dry in the sunlight. Then right before the adhesion promoter (rustoleum) I wiped them down with Rubbing Alcohol and a microfiber. Follow the directions on the can of adhesion promoter and apply your topcoat in the correct time window. I used Rustoleum bed liner on my flares, and it has held up VERY well. I painted them three years ago, its still holding on and not chipped.For exterior trim pieces, is all I need the SEM adhesion promoter and the trim black?
If I can just use the Rustoleum, then I'll save some money. The SEM is expensive. I can probably pick it up locally too. Thank you both.When I did my flares, I scuffed em with a green scotch bright to smooth em out and give the paint some "tooth" then I cleaned them real well with dishsoap (an excellent degreaser) and let them dry in the sunlight. Then right before the adhesion promoter (rustoleum) I wiped them down with Rubbing Alcohol and a microfiber. Follow the directions on the can of adhesion promoter and apply your topcoat in the correct time window. I used Rustoleum bed liner on my flares, and it has held up VERY well. I painted them three years ago, its still holding on and not chipped.
