Any ideas on front inside fender liners for a 97 tj. Only ones I’m finding have to be paired with certain flares
Your post is lacking details, are you looking for Jeep TJ factory inner fenders?Any ideas on front inside fender liners for a 97 tj. Only ones I’m finding have to be paired with certain flares
Correct, you are “likely” not going to find an aftermarket inner fender for stock fenders.Sorry for the lack of details. I’m trying to replace the factory ones with aftermarket ones similar to the ones in the picture. I’m only finding a few and it seems that I would also have to switch to that companies fender. I’d like to keep the fenders that I just installed on
I’m trying to get rid of all the open space after I did the 4” liftCorrect, you are “likely” not going to find an aftermarket inner fender for stock fenders.
You could fab some or have some fabbed up to your liking.
Begs the question, why do you want aftermarket inner fenders ?
Your pics, because of the lighting, make it very hard to see the detail above the tire. It looks fine. Is the engine bay exposed?
It looks like that is a factory flare. Just trimmed. I think he is looking for a recommended wheel well liner for looks. There are some cool looking ones out there. I agree that there wont be any change with the factory liner. You can easily duplicate the factory liners profile with thicker material. I have had good luck purchasing rubber material on amazon.
It’s not exposed was just wanting it to look betterYour pics, because of the lighting, make it very hard to see the detail above the tire. It looks fine. Is the engine bay exposed?
Honestly you should just put your good ones back on. That is, if you were smart and bought some used ones to cut up to see if you liked the look.It’s not exposed was just wanting it to look better
This is how I bought it but didn’t bother me before I lifted itHonestly you should just put your good ones back on. That is, if you were smart and bought some used ones to cut up to see if you liked the look.
Allows for you to put your good ones back on if the junk ones you cut look...like trash.
Looks worse now, if I am being honest. But thankfully if you did cut your good ones, new fender flares can be purchased for like $100.
Makes sense. Buy some factory flares and it will look a lot better.This is how I bought it but didn’t bother me before I lifted it
Hello,
This is coming in late but looks like this company makes them
